Chris_m28
TiVo box stuck on starting up flashing lights
  • My bedroom TiVo box froze the so I turned the power off as per the help guides and restarted the box. After a number of tries and disconnecting the cables I eventually got it to start up.
the following morning however when I woke up, all of the lights on the box are flashing and the standby button alternates between white and red/pink. The screen is stuck on Starting up...
I have tried to power off a number of times disconnecting all the cables. It has also been off for pretty much the whole day. When I try to power up again I’m still stuck on the Starting up... page.
I have been on hold to customer services all day and had no luck getting through.
after waiting over an hour the call ended.
Can anyone help?? Is there anything I can do to fix it?
japitts
  • 12.07K
  • 1.68K
  • 2.59K
Re: TiVo box stuck on starting up flashing lights
Sounds like either a failed box, or a software drop has gone wrong. Either way...
I wish there were a better answer other than to try calling again. There's a text message service (07533 051809) which normally responds after a day or so, or VM forum staff do pick up posts here, but their current backlog is around a week.
As a long shot, you could try swapping the boxes around just to prove the problem, but I don't realistically see it helping.
Chris_m28
There’s no way to fix this. They just replace the box with a new one.
John_GS
  • 9.18K
  • 494
  • 831
Hi Chris_m28
Good morning and welcome to the community. My apologies for the delayed reply and indeed the TV box issues.
I can see you've spoke to the team and we've replaced the TV box for you. I do hope that's sorted things. Do let me know if we can assist further.
Kind regards,
John_GS
