geraldkirk
The volume on my tivo box is too low.
Is there a setting to increase the output volume from the tivo box. I cant hear it even with the tv volume ludicrously high. Switch  over to freeview and it shatters the windows !!!!!!
  • 945
  • 79
  • 131
michaeldavis
Well-informed
Re: The volume on my tivo box is too low.
The sound signal from the V6 box can not be altered.
It is likely that the sound settings on your TV are incorrect, try the lowest setting on your TV (typically Duel sound set to stereo).
If there is no improvement then try Dolby A, Dolby B and so on until you find a setting that suits your requirements.
You can't learn anything from a mistake until you admit that you've made it.
  • 4.88K
  • 339
  • 829
Roger_Gooner
Superstar
Go to Home > Help & Settings > Settings > Audio Settings > Dolby Digital and set it to "Dolby Digital to PCM". If the volume is still too low report a fault.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
