TV sound volumes wildly different between channels
pmscott6135
Recently this has become a problem.
For example BBC on channel 101 has normal volume but changing to BBC on 601 and the volume is very much lower.
1 ACCEPTED SOLUTION
Accepted Solutions
Gareth_L
Hello pmscott6135
Thanks for your reply.
The issue you hear is one controlled by the broadcasters themselves, and is not uncommon. The volume levels can vary between channels, and it's usually adverts that are somewhat louder.
You can try these settings, to see if it helps.
Settings > Audio & Video > Audio output has three options:-
Follow Content
PCM 5.1 (HDMI only)
PCM 2.0
Gareth_L
21 REPLIES 21
Martin_N
Hi pmscott6135,
Thank you for your post. I'm very sorry to hear about the issue with your Tv service.
Does this happen on any other channels?
^Martin
Thanks Martin,
Yes, I haven't made an exhaustive survey but for example channel 143 has a  very low volume and bringing it up to normal and then changing to channel 102 the latter is far too loud.
Kind regards,
Peter
All the channel 5 programs have very low volume.
Gareth_L
Hello pmscott6135
Follow Content
PCM 5.1 (HDMI only)
PCM 2.0
Gareth_L
This has changed recently and whilst changing between BBC News on 101 is very different in level to BBC News on 601 there are plenty of non-BBC channels that also exhibit vast differences in level. These changes happened to all the affected channels recently and on the same day so I think it very unlikely that all the different networks decided to mess things up simultaneously.
The ball is in your court.
Peter
The settings on our TVO box don't correspond with those you quote but adjusting them does appear to have sorted the problem.
Peter
Thanks for the update and glad to hear altering the settings has resolved the issue for you Peter 😊 If you need any further support please don't hesitate to post on the forums and we'll be happy to help.
Rob
Sorry, it has improved it slightly but there are still some substantial volume differences and the general level is far too low.
Peter
Hi Peter, thanks for coming back to with the update.
Some variation in sound between broadcast channels is not uncommon.
We do apologise for any inconvenience caused.
Ayisha_B
