Fennboy
TV sound cuts out intermittently
my TV sound cuts out for a second at random times on various channels, connected to a V6. The old TiVo upstairs works fine, It works ok playing Netflix thru a Firestick and playing BluRay movies. I’ve swapped TVs and the problem is still there so must be the V6. Any clues?
  • 10.5K
  • 1.44K
  • 3.1K
Re: TV sound cuts out intermittently
Hi Fennboy,
It may be a faulty HDMI cable. Try using a different one to see if that helps.
You could also experiment with the sound output.
To do that using the remote control HOME > Help & Settings > Settings> Audio> Dolby Digital> Dolby Digital to PCM
Dave
