ubersetis93
TV V6 Remote Control Distance
Hi all,
I am planning a new entertainment setup in my new house and wondered if the new TV V6 remote will be able to work from different rooms around the house through walls/floors.
I want to put the TV V6 box under the stairs and have it connected to multiple TVs around the house. I'm hoping the remote will be able to talk to the box from different locations around the house to change the channel etc.
Has anyone had any experience with this?
Thanks!
dannylau
  • 11.18K
  • 909
  • 2.54K
Re: TV V6 Remote Control Distance
It would probably work but for 4k viewing a max distance of 3 meters is recommended for hdmi leads, also virgin equipment doesn't always play nicely with hdmi splitters
