TV Flickering with small box
helen49952
Hi, would anyone happen to know why my tv is flickering with the V6 box ? I think that’s what is it called.I have changed all the leads for new one new HDMI but still flickering and colour going up and down in brightness.I have tried other things on tv and it does not happen with them.Any ideas please?
1 ACCEPTED SOLUTION
Accepted Solutions
japitts
Can you post a video of the problem?
Does it happen with.. live TV? OnDemand? Recordings?
3 REPLIES 3
japitts
It happens only with live tv.When I am watching live channels.I do not use anything else on the box.I go to my smart tv apps if that makes sense?!
Hi @helen49952, thanks for coming back to us. Do you possibly have a video of the fault as advised by @japitts?
Looking into your profile, it appears that you have a duplicate thread, in which a member of our team has responded to you.
Please also refer to this and please place the response to both posts on this thread, so it's all in one place.
David_Bn
