Kate987
T6 box stuck on starting up
Spoiler
The TiVo box is stuck on the starting up screen. Even after 4 hard resets and unplugging.
Been like that for about 8 hours now.
Suggestions.
Spencer_A
  • 116
  • 18
  • 41
Re: T6 box stuck on starting up
Hello
Could you switch the box off using the switch located at the back of the box, leave it for a minute and then switch it back. When it comes back on, if you press & hold the < & > & OK buttons until the screen changes, it should bypass that.
Hope this helps!
Why not try our text messaging service? It's a great way to get help with your services.
Just send your query to 07533051809 and we'll text you back.
We're open 8am - 8pm Monday to Friday, 8am - 5pm weekends.
If my post has helped you at all please mark it Helpful or give a Kudos, thanks!
