  • 165
  • 5
Up to speed
Store problem
Why can’t I log on to Virgin Media store? Really annoying especially as it’s the only place that has the Dracula TV series. Frustrated
  • 17.28K
  • 1.83K
  • 4.09K
Re: Store problem
Have you registered for the Virgin Media Store and input the card you want to pay for the material with?
It is a different login than your My Virginmedia one.
Go here to register:
https://www.virginmediastore.com
  • 165
  • 5
Up to speed
Re: Store problem
It wouldn’t let mr logon at all. I laboriously typed in all me details, then it would freeze and finally give me an error message
  • 165
  • 5
Up to speed
Re: Store problem
Yes I have
