bashypack
  • 17
Message 1 of 13
Sound and picture stutter
I know this has been mentioned before and I commented on an older thread but no reply - sound and picture stutter and stop until the unit is reset nearly every time we use it - it is extremely frustrating.
Melissa_F
  • 2.78K
  • 160
  • 219
Moderator
Moderator
Message 2 of 13
Re: Sound and picture stutter
Hi bashypack,
Thanks for your post.
Sorry that you're still having problems with the sound and picture stopping every now and again.
Does this happen on every channel or just certain ones?
Do you notice it on live TV aswell as on-demand or catch up?
Have you been able to try the box on another TV to see if the issue continues?
Let me know,
Melissa
bashypack
  • 17
Message 3 of 13
Yes it seems to be an 'equal opportunities' problem happening on any channel at any time - it doesn't happen every single time but quite frequently and the TV has been changed.
Melissa_F
  • 2.78K
  • 160
  • 219
Moderator
Moderator
Message 4 of 13
Thanks for confirming.
Is the box a V6 and currently turned on and ready to use?
bashypack
  • 17
Message 5 of 13
Yes it is a V6 and it is on standby..
Melissa_F
  • 2.78K
  • 160
  • 219
Moderator
Moderator
Message 6 of 13
Okay, can you please make sure the box is turned and can you do the following:
Go in to Home > Help and settings > Settings > Video Output.
Can you let me know what the video output format is showing as please?
Melissa
bashypack
  • 17
Message 7 of 13
It is set to 2160p
Alex_RM
  • 4.28K
  • 247
  • 325
Message 8 of 13
Thanks for getting back to us bashypack,
Can you confirm if the chosen input has the words "Not supported" within the brackets on the video output screen?
Alex_Rm
bashypack
  • 17
Message 9 of 13
No it does not.
Zak_M
  • 3.37K
  • 213
  • 336
Message 10 of 13
Thank you for coming back to us,
Are you still experiencing these issues?  Have they been consistent since your first reported this to us?
Kind regards.
Zak_M
