itsallgravy1
Message 1 of 11
Sound and picture "stutter" until box is re-started
This seems to be a regular topic looking at all the similar messages to this, but it doesn't make the situation any less annoying.
Since upgrading to the new V6 box I'm experiencing sound and picture "cut outs" for a second or 2 at a time, and this continues unless I switch the box off and back on again. It happens with standard and HD channels and also with recorded TV.  It can also start up and do it again if watching TV for a longer period of time even after switching off and back on again.
I've tried switching cables it makes no difference, have also tried a different TV! Again, it still does it.  So I'm certain it's the box.  A few people have mentioned that it's an issues between V6 and Samsung TV's but I have an LG.
Can someone advise when there'll be a fix for this?  I'm unhappy paying for an upgraded service that isn't up to what it's supposed to do!!
LeicesterLad
  • 15
Message 2 of 11
Re: Sound and picture "stutter" until box is re-started
Me too! I also have an LG tv, so it isn't a Samsung thing. Just annoying.
itsallgravy1
Message 3 of 11
It's ridiculous.   There are so many threads on here about it, but no one from Virgin seems to be helping!
Louise_F
  • 3.12K
  • 116
  • 157
Message 4 of 11
Hi itsallgravy1,
Thank you for taking the time to post in the Community.
I'm really sorry to hear your experiencing issues with the picture and sound dropping out all the time.
I have located your account using your Forum details and run some diagnostic checks for you The box is showing as offline at the moment so not able to get a full reading but I can see the downstream signal levels are not within our required specifications and that may be causing some issues with this.
I would like to arrange for an engineer to look at this for you if you don't mind.
I have sent you a private message. Just click on the little plum envelope at the top right hand side of the page to access your inbox.
Speak soon,
Louise
New around here? Find out more about the Community by checking our "Getting started guide"
Louise_F
  • 3.12K
  • 116
  • 157
Message 5 of 11
Hi LeicesterLad,
I'm sorry to hear you are also experiencing picture and sound drop outs.
I have located your account using your Forum details so I can run some diagnostics on the box for you but I have been unable to make a connection to the box. Can you please advise if the box was powered on at the time of my post?
When was the last time you rebooted the box?
Speak soon,
Louise
dylbot
  • 14
Message 6 of 11
I get the same problem. Used to get bad break up on the old TiVo now the stuttering on v6 plus volume differences on some of the channels, e.g. film 4 hd will be muffled while standard def is fine. Have a feeling it's virgin signal strength more than the box, I live in a high density area one of the engineers said once when 'fixing' the problem that there's just too many people and not enough signal. My phone hasn't work for longer than a week for years either, I just don't bother to call then out to fix it anymore. I'm sure they'll still put the price up twice a year though.
David_Bn
  • 4.91K
  • 226
  • 402
Message 7 of 11
Good Morning dylbot,
Thanks for your post on our Community Forums,
Sorry to see that you've been having this issue with our V6 box.
Have you attempted any of the above information, like swapping HDMI cables or evening switching the HDMI port on the back of the TV?
Have you been able to see if there would be a different result when an alternative TV set is used?
I can look into this further to see if there is a fix via PM if you would like my assistance
David_Bn
bashypack
  • 17
Message 8 of 11
Hi - Sorry to resurrect an old thread but has this been sorted out yet as we keep getting the same problem and it is extremely frustrating!
Thanks!
cleothecat
  • 12
Message 9 of 11
Same here. Screen and sound cuts out for a few seconds and then returns. Been happening for approx. two weeks and getting more frequent. Usually worse between 7 and 9 pm but can happen any time. TV is unwatcheable when at its worst. Restart sometimes temporarily helps.
Very very very unhappy. With this and the Amazon Prime problem https://community.virginmedia.com/t5/Virgin-TV-V6/Amazon-Prime-not-working-on-V6-box/td-p/4041180 it's looking like back to Sky when my contract ends.
bashypack
  • 17
Message 10 of 11
We are getting the same issue and it is very frustrating - can you run the same diagnostics on our unit please.
