No it happens on all channels. BBC, Eurosport, Channel 4, etc etc.
Both boxes are DCX960 V6, hardware 2048.0
And I followed the Troubleshooting guide - this works but its every a day often multiple times- Try changing channels, then switch back
again.
Doesnt seem to happen on recordings
Audio and Visual: The picture and
sound are out of sync?
again.
Go to the screen, then press to
go back to live TV.
Check that all your cable connections are
plugged in properly.
If none of these suggestions work, restart
your Virgin TV V6 box.
thank you
