Shaukey57
  • 5
Message 1 of 9
Sound Issue
I am having issue with sound after every 10 to 15 minutes the sound goes for few seconds and comes back. I have changed my HDMI cable and still have the same problems. I also restarted the box as well.
japitts
  • 20.61K
  • 2.64K
  • 4.72K
Message 2 of 9
Re: Sound Issue
Is this on live TV? Recorded programmes? OnDemand? I'm getting here, at whether the input source makes any difference.
Toggling the PCM sound off/on via Help & Settings > Devices > Audio is the other test to try - this would epecially be a good check if this happens across different sources.
Shaukey57
  • 5
Message 3 of 9
Re: Sound Issue
live TV
japitts
  • 20.61K
  • 2.64K
  • 4.72K
Message 4 of 9
Re: Sound Issue
If this is specifically on live TV and not other sources, it would tend towards it being a source issue rather than output one - so are there any specific channel(s) affected? Including SD/HD where both exist
Have you tried, as per my previous post, toggling the PCM sound off/on via Help & Settings > Devices > Audio is the other test to try - this would especially be a good check if this happens across different sources.
Shaukey57
  • 5
Message 5 of 9
Re: Sound Issue
Thank you. Will try to do what you requested and let you know.
Shaukey57
  • 5
Message 6 of 9
Re: Sound Issue
I have tried and disconnected the Soundbar and still have the same problem. Now it's direct connection to TV and still have the same problem.
japitts
  • 20.61K
  • 2.64K
  • 4.72K
Message 7 of 9
Re: Sound Issue
How about my other questions..
1: Is this affecting live TV? OnDemand? Recordings?
2: If live TV only, are any specific channel(s) - including SD/HD particularly affected?
3: Have you tried toggling the PCM option via the Help & Settings menu?
Shaukey57
  • 5
Message 8 of 9
Re: Sound Issue
Thanks and sorry yes it effects the live TV. I haven't checked the onDemand and Recordings.
you I should try to toggling PCM option? How to get to help? then setting menu?
japitts
  • 20.61K
  • 2.64K
  • 4.72K
Message 9 of 9
Re: Sound Issue
Can you check and report back as & when? It may help prove where the issue lies.
As per my post#2 above... Toggling the PCM sound off/on via Help & Settings > Devices > Audio is the other test to try
