Sound Connection
I have a  Phillips 5.1 Home Cinema system that's connected to my TV via a Scart plug. When I had Sky it enabled me to adjust the sound via the Sky remote. Now I Have a V6 Box I have to use the dedicated DVD Player's remote. Is there a way round this, please?
  • 49
  • 16
  • 22
Re: Sound Connection
Hi Teeedeee
Thank you for you're concern.
If you would like to private message me ill be willing to help.
Hope this helps
Kieran
I am a Virgin Media Field Technician. All and any advice given is based on my experience in the field or my personal experiences with my own set up at home. If my answer was helpful to you please Mark as helpful or consider leaving the post some Kudos.
