on 26-10-2023 18:18
Our old v6 remote started playing up with some buttons not working so I ordered a replacement. Very straightforward.
However, the replacement has issues. Symptoms include, buttons not responding unless you press them repeatedly, particularly the main circle of navigation and ok buttons. I've setup in both IR and paired format, changed the batteries and experimented with a universal remote replacement (which we use on another TV in the house). All points to a dodgy replacement remote. Can I get another remote control without having to pay?
Answered! Go to Answer
on 01-11-2023 09:12
Okay thank you.
I will send you a private message now so we can order one for you.
Please look out for the purple envelope in the top right of the page and pop back to me when you can.
Vikki - Forum Team
on 30-10-2023 08:58
Hey @bumpernick,
Welcome back to the Community Forums and thanks for the post.
Sorry to hear you have been having these issues with your TV remotes, it is certainly not something we want our customers to go through. With our remotes you should be bale to re-order a new on again if this is faulty with no charge, if you visit our website Here and let me know if you can order one, if not come back to me here and I can assist further.
Joe
on 30-10-2023 09:07
Thanks for your help Joseph. I've used the link but it says the replacement will be £9.99. Can you help with this?
on 01-11-2023 09:12
Okay thank you.
Vikki - Forum Team
