Barfion
Replacement remote not working
I received a replacement remote today but it won’t let me update the volume controls for my TV, I press and hold the TV /CLEAR buttons for longer than 10 seconds without any green lights being seen only a flashing red light occasionally. I have successfully done this with every previous remote control not sure what’s going on with this one - can’t get through to a human either to discuss issues. Any ideas anyone? Batteries are new as came with the new remote.
  • 7.86K
  • 1.16K
  • 2.14K
Re: Replacement remote not working
Hi Barfion,
Have you tried following the advice on this page? virgin-tv-pairing-tv-remote
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
