Replacement cable
Hi, does anyone know an email address or number to contact in regarding a replacement F net cable? Thank you
  • 28.82K
  • 1.35K
  • 4.96K
Re: Replacement cable
what is a f net cable?
Click to learn more about VIP
Use Kudos to say thanks
  • 3.88K
  • 394
  • 685
Community elder
Hi I think you mean ETHERNET cable it always helps to post correct details, go on line they are fairly cheap, do you have a V6 box if so a cat6 cable is the right one, from £2.59 to £9.75 on EBay depending on the length.Regards Micky
