Chris_Watson
Replacement Mains Power Lead
Where can I purchase a replacement mains power supply plug and lead for my Virgin TV V6 TV box please.
japitts
  • 19.22K
  • 2.49K
  • 4.4K
Re: Replacement Mains Power Lead
If you've got a fault with your existing one, you can probably order a replacement through VM directly.
Either by waiting around here (which might be a few days - a tad tight if your box isn't working now) or by calling in on the usual number. 150 from VM or 0345 4541111 from any other network.
Lee_R
  • 6.24K
  • 288
  • 650
Hi Chris_Watson thanks for posting and welcome to our community.
Sorry to hear you're needing a new power supply unit for your V6 box.  I would love to help you with this.  I am going to send you a private message.
Lee
