Thanks for the response there HagbardCeline,
Can I ask does the issue with the channels occur when the box is online for some time as well?
Secondly it seems that you may need a new remote, with the link above if you sign into your MyVM you can order a remote from there, if any issues appear then pop back up and we'll order it.
Kain
