suthron
  • 18
Remote key click
How do I stop the annoying noise when a key is pressed on the remote
Ernie_C
  • 18.58K
  • 2.04K
  • 4.58K
Re: Remote key click
Sound Effects Volume in Audio Settings in Settings.
Graham_A
  • 16.54K
  • 2.32K
  • 7.07K
Home, help & settings, settings, audio, sound effects volume, off.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
thenel
  • 129
  • 5
Dialled in
I've tried this but it had no effect. if I'm scrolling or touch any button the remote clicks.  it's very annoying!
can the buttons on remote be silenced? I know some people like a noise/response when they press a button but not me.
