on 08-05-2023 18:16
the remote control for my TiVo is very slow to respond on the screen. Typing numbers or moving between programmes is far too slow. It’s not the remote or the batteries as I see it register the commands by the flashing lights. The TiVo box is old though so does it need replacing? Prob 2016 ish
on 08-05-2023 18:35
You've referred to a TiVo, but posted in the V6 forum. Which do you have?
https://www.virginmedia.com/care/tv-fault/which-tv-box
on 08-05-2023 18:40
I have seen your comment that it isn't the batteries, however I would suggest changing them if you haven't already done so. I had this same issue with a V6 box powered by Tivo recently and a battery change made a huge difference.
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Please read the FAQs
on 10-05-2023 18:56
Hi @Normski2
Welcome to our community forums and thank you for your first post.
Sorry to hear you are having issues with your TV box/ Remote. We can understand that this is not ideal and we want to best help. How long has this issue been ongoing? Also as mentioned by @japitts, what TV box do you have? https://www.virginmedia.com/care/tv-fault/which-tv-box I have been able to access your service and I can see you placed an order for a new remote. Is the issue still ongoing?
on 10-05-2023 20:05
new remote hasn’t arrived yet. So I’ll text once it does and refer back
thanks
on 12-05-2023 20:19
Hi Normski2,
Once ordered the remote can take up to 5 working days, please let us know if you do not receive it within this time, if you need any further help in the meantime, please do not hesitate to reach back out.
Paul.
