Robbly
Remote control partially not working
I’ve started experiencing problems with certain features of my remote not working with my V6 box. These are: not being able to access Guide other than via the Home button; Volume down not working; red button not working. I’m also not able to access the YouTube channel. I’ve tried all the suggestions in Help including unpairing and repairing the remote. I’ve got an LG TV
LittleMick73
  • 4.92K
  • 513
  • 839
Superstar
Re: Remote control partially not working
Hi phone and go down the TV faults route they will send you a new one in the post. Regards Micky
Robbly
Thanks. That’s brilliant
Rob
Hfrancesc
We have similar problem - also won’t let you unlock with the code if before 10, BBC IPlayer takes forever to load, Netflix won’t respond, my fingers are going numb from pressing the buttons.  New Duracell batteries inserted!
ive tried to call but always says 40 minute wait and advises to contact online but I can’t find the place to do this.
Any advice please?
  • 5.66K
  • 910
  • 1.33K
Hero
Hi Hfrancesc,
You need the TV Faults option when dialling 150 from your Virgin landline, or 0345 454 1111but best to call at 8am to avoid call queues
You could try the text messaging service. Just send  a text with a description of new remote  to 07533 051809. Your message will go into a queue and a representative will respond to you as soon as possible. It may take a few days.
For now you could download the TV Control app and use that until you receive a replacement remote
https://www.virginmedia.com/shop/tvgo-tvcontrol
Dave
Hfrancesc
Thank you - I'll give it a try.
