Hi.
I have to Pair my remote control almost every day with the V6 box.
When it fails, the red led flashes on the Remote when I press a button, but there is no corresponding flash on the V6 box however close I get.
This suggests that it hasn't reverted to IR with the V6 box.
If I press the remote power button the led flashes red when I let it go, but the V6 box ignores it.
If I hold the power button, after a few seconds the led flashes green and the TV switches on or off.
I assume this is IR signalling.
There are new batteries in the remote.
Also, if I switch the V6 box off with the power switch on the back and switch it back on after about 30secs, the remote works OK.
I can put the remote in my pocket and it still works.
Does this indicate a V6 box or remote control problem?
Are there any suggestion for further testing that I could try to diagnose this problem?
Thanks.
