rgale40
  • 51
  • 7
Message 1 of 5
Remote control issues.
I have three V6 boxes in my home & recently all three remote controls have started un-pairing from their respective boxes if they're not used for a while, such as overnight or during the day when we're all out of the house.
In order to re-pair the remotes I have to remove the batteries for several minutes & then manually re-pair by pressing & holding the channel down button on the box, followed by pressing/holding the info button on the remote. If I try this process without first taking out the batteries it doesn't work. Similarly, selecting the 're-pair' option from the 'settings' menu on the home screen doesn't work either.
Once I've got the remotes re-paired everything is fine until their not used for a while & then the whole shebang starts again.!!
It's probably worth mentioning that none of the V6 boxes are switched off or unplugged when not in use & I've tried re-setting all of the boxes which doesn't help.
Needless to say, it's extremely irritating and to have the same thing happen to all three of my V6 boxes at exactly the same time surely can't be coincidence..??
Any ideas anyone.?
jb66
  • 12.42K
  • 925
  • 1.82K
Message 2 of 5
Re: Remote control issues.
Have you put in cheap batteries like poundland ones? I've seen those cause strange actions on the remote
  • 7.86K
  • 1.16K
  • 2.14K
Message 3 of 5
Have you checked the remote battery level on each box?
Home > Help & Settings > System Info > System Info and then go to the 3rd page. Once the battery levels get down to around 30 per cent they can cause problems including losing pairing.
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
rgale40
  • 51
  • 7
Message 4 of 5
Hmmmm....never thought of that. Thanks for the reply.
rgale40
  • 51
  • 7
Message 5 of 5
Thanks for the reply. I've had a look at the remote battery levels on all of my remotes & it just says 'unknown'.
I'll swap the batteries out & see if that helps.
