Remote control double signal issue
extrusion
My remote has started doing this odd thing where it seems to send the button signal twice. The white light on the box flashes twice instead of once every time I press a button. This makes the box seem to respond really slowly when going through menus etc.
Last time I reset the remote and set it back up to control the TV and everything was great again. Now it has happened again but I can't reset the remote, holding Clear +TV does but make the remote flash a green light, instead a red light flashes once.
Any ideas?
1 ACCEPTED SOLUTION
Accepted Solutions
extrusion
Ok so it seems it's best not to ignore the advice to change the batteries.
3 REPLIES 3
extrusion
*I meant does NOT make the remote flash a green light above!
extrusion
Hi extrusion,
Thank you reaching out to us in our community and welcome back, it has been a while, hope you have kept well, sorry to hear you have been facing issues with your remote control, has changing the batteries now resolved your issue?
Paul.
