Grist22
Remote Programme for 2 x Tivo Boxes
Does anybody know how to pair 1 Tivo remote to work with 2 x Tivo boxes?
I have an old remote that works on both boxes but the new remote I have just received only works on 1 Tivo box
BenMcr
  • 21.44K
  • 2.34K
  • 4.3K
Re: Remote Programme for 2 x Tivo Boxes
Do you have V6 boxes or TiVo boxes?
The older TiVo remotes use IR commands so will work with any box they're pointed at (including V6 boxes)
The V6 boxes use RF remotes to need to be 'paired' to a box to work, and aren't design to work with multiple boxes at the same time.
If you do have V6 boxes, you can download the TV Control app to an Android or iOS device and that can be using to control multiple V6 boxes from one device. You can also use TV Control with TiVo boxes, but they need to be connected to your Hub before the Remote functions are possible.
Grist22
Re: Remote Programme for 2 x V6 Boxes
Sorry for the confusion, I have 2 x V6 boxes, I have an old remote that works on both boxes so I know it is possible to setup
BenMcr
  • 21.44K
  • 2.34K
  • 4.3K
Yes - the V6 boxes will respond the IR Commands from the older TiVo remotes. That was so they could be used as backup while you wait for replacement remote.
However the V6 boxes are designed to work with their RF remotes and each remote is designed to work with its paired box
Grist22
I think I have confused myself and othe people so sorry.
I have 2 x V6 boxes with the orginal remote that works on both boxes.
I have received a new remote which I can't get working with box boxes like the orginal V6 remote I have
BenMcr
  • 21.44K
  • 2.34K
  • 4.3K
The V6 remotes are not designed to work on multiple boxes by default. They will fall back to IR if the setup has gone wrong, but it's not that easy to get the remotes to do it on purpose.
You *may* be able to do it by resetting the remote:
https://www.virginmedia.com/help/virgin-tv-using-tv-remote#tab1
And then keeping it out of range of the V6 boxes for a period of time until it gives up trying to pair to one of the boxes.
