Weefifer
  • 38
Message 1 of 20
Re: v6 sound issues live/recorded tv
You are not alone, have the same thing but along with sound loss for a second it freezes the picture to. Sometimes it’s few seconds. It’s a pain, 4 engineers later, still the same. Fed up.
japitts
  • 12.22K
  • 1.7K
  • 2.63K
Message 2 of 20
V6 sound issues
@Weefifer
I've moved your post to a new thread, else that one is at risk of becoming more "me too" type posts, where the underlying issue is likely specific to your installation and/or kit somehow.
With that in mind, and since I don't think you've posted about this before, can you clarify whether this sound issue...
1: Affects OnDemand or streaming services?
2: Affects live TV and the resultant recordings, in which case are there any specific channel(s)?
Is your V6 sound fed via any A/V kit, or just HDMI to your TV?
Steven_L
  • 5.29K
  • 371
  • 538
Message 3 of 20
Hey @Weefifer
Thanks for getting in touch with us here with your TV issues.
Would you be able to answer the questions from japitts as this will help us diagnose the issues that you're having.
Regards,
Steven_L
Weefifer
  • 38
Message 4 of 20
Re: V6 sound issues
Hi, it can be any channel, recorded, live, streamed, watching a film. It just drops sound for a second then picks it back up. Sometimes the picture pauses too.
i have the v6 box connect to tv hdmi and I have a sound bar through hdmi arc. I have the sound bar & 2 speakers, grouped to give 5.1 (connected wireless), they are all Samsung, tv 9months old. It does it even if we just set sound to tv arc.
hope that helps
Weefifer
  • 38
Message 5 of 20
Done. Thanks
Steven_L
  • 5.29K
  • 371
  • 538
Message 6 of 20
Thanks for coming back to us @Weefifer.
Does this happen if you don'y use the V6 like watching a DVD or terrestrial TV via the built in free view capabilities?
Regards,
Steven_L
Weefifer
  • 38
Message 7 of 20
Sorry, don’t watch many DVD’s lol and only watch virgin media or prime
Steven_L
  • 5.29K
  • 371
  • 538
Message 8 of 20
What have the 4 engineers advised that the issues could be as I'm having problems finding any issues with your box or services at the moment?
Has your box been replaced at all?
Regards,
Steven_L
Weefifer
  • 38
Message 9 of 20
Had both downstairs and upstairs boxes replaced, On upstairs one, if watching a recording it sometimes  freezes and then tells me network to slow, had different errors each time. Often getting kicked off WiFi on phone, tablet, drops WiFi for sound bar and speakers. Have now stopped the smart channel select as advised by one engineer, hopefully that helps. We have a booster upstairs, one of the old ones from virgin as it’s really poor WiFi when away from router in living room.
japitts
  • 12.22K
  • 1.7K
  • 2.63K
Message 10 of 20
It sounds like part of your underlying issue is wireless, which isn't something VM have much control over.
The V6 does have a few options for checking the quality of your wireless connection.
1: Home > Help & Settings > Settings > Network, and look in the top-right for the signal strength of the wireless connection.
2: Home > Help & Setings > Help > TV Care > TV Speed Test. This will check that your box's connection has the required speed for streaming services.
