Re: V6 box flashing and stuck on starting up
Familyfavourite
Hello we have the same problem. The internet is fine for our other Virgin boxes and mobile etc devices, but one V6 box just keeps flashing. Have tried re-booting the hub to no effect. Grateful for any help on this. Thanks!
1 REPLY 1
Chris_W1
Hi Familyfavourite, thanks for the message and sorry to hear that you are having issues with the set top box and will send you a PM so that things can be looked into further.
Kind regards, Chris.
