Anthf
Message 1 of 5
Re: V6 Remote Pairing Problem
Hi I am having same problem just received new v6 box and won't pair.
Put new batteries in remote unpaired then try to repair of getting green light.
Been on phone to vm over an hour still no answer.
Tags (1)
japitts
  • 8.54K
  • 1.2K
  • 1.66K
Message 2 of 5
V6 Remote Pairing help
Have you tried following the instructions on https://www.virginmedia.com/help/virgin-tv-pairing-tv-remote ?
What's happening when you try?
Anthf
Message 3 of 5
Re: V6 Remote Pairing help
Nothing happens that's the problem.
I'm no further forward either.
Will ring them again today.
Stan4olino
Message 4 of 5
1. Press the Channel Down button on
the front of the Virgin TV V6 box for
10 seconds.
2. Then, hold the Info button down on the
remote for 7 seconds.
3. The light in the top of the remote will
flash green twice.
4. Your remote is now paired, so it'll work
even if your box is hiding in a cupboard.
Anthf
Message 5 of 5
Thanks so much now paired just awaiting on box install itself.
