JayJay21
Re: Really poor picture quality ( low bitrate ) on Sky Sports and BT
Hi did you get the problem resolved, I have noticed the same problem. The picture quality has definitely gone down on sky sports HD?.
japitts
  • 12.23K
  • 1.7K
  • 2.64K
I've not noticed any degradation in PQ on any Sky or BT Sports channels recently.
Are there any specific channels you've noticed this on?
Camtest
  • 6
Same here, has definitely degraded recently. BT via the V6 is fine, as is football on Prime, it's definitely an issue with the Sky Sports HD channels on the V6.
