SallyS187
Message 1 of 5
Re: Pink/purple and white flashing lights - V6 box
Also having this problem, with Pink & White flashing lights and stuck on Starting Up screen. Only had Virgin Media a week and it's broken already! 😞
Tried all the common fixes - resetting, checking wires etc.
Please help.
japitts
  • 11.99K
  • 1.66K
  • 2.56K
Message 2 of 5
@SallyS187
You'd added your post to a (long-solved) thread so I've started a new post for you 😉
Sounds like your box could be faulty to me - possibly a failed software drop but all the same. Best call it in, 150 from a VM phone or 0345 4541111 otherwise.
Out of interest, how is your V6 connected to your homehub for the internet - is it WiFi or Ethernet?
SallyS187
Message 3 of 5
It’s on Ethernet. Just randomly stopped working the other day 😞
japitts
  • 11.99K
  • 1.66K
  • 2.56K
Message 4 of 5
has your box worked its way out of the boot loop yet? If not, and the Ethernet cable is securely connected, I'd suggest calling your fault into VM.
150 from a VM phone, or 0345 4541111 from any other phone.
SallyS187
Message 5 of 5
Thanks for the tip, but it's impossible to get through on the phones. Spent an hour on hold, twice, only to get disconnected, twice.
So now, I'm paying for a service I can't access. Great.
