johnhignett1
Re: ITV hub problem
I have a V6 box and have the same problem, I only see previously shown episodes even though they advertise on the HUb that all episodes are available
Do you know the answer
japitts
  • 8.61K
  • 1.21K
  • 1.67K
ITV hub problem
@johnhignett1
I've moved your "me too" post to a new thread to not get replies confused 🙂
The "ITV Hub" can mean one of two things.
1: Virgin OnDemand programmes accessed by the CatchUp menu, perhaps clicking on an "ITV Hub" logo and maybe even having graphics for "ITV Hub".
2: The "ITV Hub" app that you get to via Home > Apps > All apps > ITV Hub.
If you follow option 2 for the ITV-specific app, you should find the episodes you're looking for. Once they are broadcast on ITV, they should be available by option 1 as a CatchUp programme.
