jgnotts
  • 30
Message 1 of 5
Problems with Fred Dibhan recordings BBC4
I've been recording these programs on BBC4HD by setting each one individually rather than a series link. Before Wednesday and Thursday last week all was ok but then..
Two recordings at the end of last week both had Audio Descriptions turned on by default when I started playing them back - I've never had this feature switched on before and it's never happened before. I got rid of it by toggling this setting on and then off again for each recording during playback.
Then last night the recording of the program at 7pm recorded 6 seconds and that was it. There was no error code with it.
So I set a recording of the repeat of this program in the early morning and this didn't record at all and had an error code of R120 when I looked in the recording hiccups.
japitts
  • 12.01K
  • 1.67K
  • 2.57K
Message 2 of 5
Re: Problems with Fred Dibhan recordings BBC4
I've not come across R120 before, or anything similar. Was there any description in hiccups alongside the code?
And although you say it was overnight - there wasn't a tuner clash was there?
nodrogd
  • 16.79K
  • 1.97K
  • 4.08K
Message 3 of 5
Its an Authorisation issue.
This is the only other time I have seen it mentioned:
https://www.cableforum.uk/board/showpost.php?p=36021914&postcount=10
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
jgnotts
  • 30
Message 4 of 5
Yes mine said Not Authorised.
I didn’t have recording clashes.
I’ve got the program at 7pm tonight set to record so will see if that works.
I’m pretty sure the one that was supposed to record at 7pm last night didn’t actually start recording until the program was over and then it just recorded 6 seconds worth.
jgnotts
  • 30
Message 5 of 5
The program tonight recorded fine and doesn’t have AD enabled.
I’m half way through watching it and so far so good.
