sdunwell2612
Problem with TV picture breaking up
Hi for a couple of weeks now my TV has been breaking up with many channels on my V6 box. I’ve tried different HDMI cables including a brand new one and no change. Can someone check my connection please? Thanks
japitts
  • 12.04K
  • 1.67K
  • 2.58K
Re: Problem with TV picture breaking up
When you say "many channels", are there any in particular? This may potentially help ID the cause.
Otherwise the best way to get your box checked over will be to call TV Faults on 150 (or 0345 4541111). If you've rebooted your box once and the picture is still breaking up, you have a fault somewhere.
sdunwell2612
thanks it’s been an issue on sky 1, bbc 1, Comedy Central, some kids channels etc
japitts
  • 12.04K
  • 1.67K
  • 2.58K
HD/SD or both?
The more specific you can be 😉
sdunwell2612
Both lol
japitts
  • 12.04K
  • 1.67K
  • 2.58K
Taking Sky One HD as an example, it might be worth checking (package dependent) Sky Disney HD, Sky Premiere HD, BT Sport 1 HD & BT Sport ESPN HD.
If any of those are affected, then you almost certainly have a signal fault.
Call VM to report it. Either of the phone numbers previously mentioned, and follow the prompts for "I have a fault with my TV service"
