Refgizmo
  • 9
Message 1 of 15
Poor wifi signal in my home.
I have encountered a poor wifi signal within my home.
If I reboot the box, it will work better (nowhere as good as usual) for a few hours before we have to reboot again.
Anonymous
Not applicable
Message 2 of 15
Re: Poor wifi signal in my home.
the wifi on the hub is weak at best.
Its possible someone else has a wireless device that might be interfering. when you reboot the hub should pick what it thinks is the best channel. but other devices around will do the same so may end up sharing channels
Andrew-G
  • 6.99K
  • 1.22K
  • 3.06K
Message 3 of 15
Unless you KNOW it is a wireless issue, it could be a broadband problem.  If you've left the hub on its default settings, the "intelligent wifi" feature should in theory switch channels for optimum wireless performance, so the beneficial impact of a reboot makes me suspect it could be the hub losing connection with VM's network gear.
I'd suggest posting your router's status page data for Downstream, Upstream and Network log (as text, not screenshots) and we'll look for things that might be amiss.
Refgizmo
  • 9
Message 4 of 15
Thank you.
Where do I get the status page data from?
  • 6.49K
  • 1.01K
  • 1.61K
Message 5 of 15
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return.
Don't login, instead below there click on Check Router Status
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
Andrew-G
  • 6.99K
  • 1.22K
  • 3.06K
Message 6 of 15
Paste the numbers below into your browser address bar:
192.168.0.1
That should bring up a login page.  Don't bother to log in, but click on the link "Check router status", that will bring up a window with five tabs.  All we need is the contents of the three tabs variously titled Downstream, Upstream, and Network log.  They're long pages, so scroll down to select all of it, or use Ctrl-A to select all, Ctrl-C to copy, and then Ctrl-V to paste into separate replies (assuming you're using a device with a physical keyboard).
Refgizmo
  • 9
Message 7 of 15
Downstream
1163000000837256 qam4
21390000009.436256 qam1
31470000008.536256 qam2
41550000008.436256 qam3
51710000007.836256 qam5
6179000000736256 qam6
71870000005.635256 qam7
81950000004.535256 qam8
92030000005.436256 qam9
102110000005.536256 qam10
112190000005.436256 qam11
122270000005.336256 qam12
13235000000536256 qam13
142430000004.936256 qam14
152510000004.536256 qam15
16259000000436256 qam16
172670000003.936256 qam17
182750000003.736256 qam18
192830000003.536256 qam19
202910000003.536256 qam20
21299000000436256 qam21
22307000000436256 qam22
233150000003.236256 qam23
24323000000336256 qam24
1Locked37.3200
2Locked36.6130
3Locked36.6100
4Locked36.670
5Locked36.3140
6Locked36.6190
7Locked35.71542291
8Locked35.5610
9Locked36.6180
10Locked36.6260
11Locked36.6190
12Locked36.3330
13Locked36.6110
14Locked36.6100
15Locked36.3170
16Locked36.360
17Locked36.3100
18Locked36.6260
19Locked36.3260
20Locked36.3160
21Locked36.6120
22Locked36.6100
23Locked36.380
24Locked36.6180
Refgizmo
  • 9
Message 8 of 15
Upstream
1462000004.1512064 qam3
2394000174.1512064 qam4
3536999794.25512064 qam2
4602999474.45512064 qam1
3ATDMA0000
4ATDMA0000
Refgizmo
  • 9
Message 9 of 15
03/10/2020 20:25:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 18:40:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:36:48criticalTFTP Request Retries exceeded, CM unable to register
03/10/2020 17:36:48criticalTFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:36:42criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:36:30noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:32:51criticalTFTP Request Retries exceeded, CM unable to register
03/10/2020 17:32:51criticalTFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:32:49criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:30:15noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:29:0criticalTFTP Request Retries exceeded, CM unable to register
03/10/2020 17:29:0criticalTFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:28:58criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:25:7criticalTFTP Request Retries exceeded, CM unable to register
03/10/2020 17:25:7criticalTFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:25:5criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:24:0noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:21:20criticalTFTP Request Retries exceeded, CM unable to register
03/10/2020 17:21:20criticalTFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 17:21:14criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andrew-G
  • 6.99K
  • 1.22K
  • 3.06K
Message 10 of 15
Looks to me like a broadband problem, not wifi (although the wireless performance of the Hub 3 is weak, as @Anonymous says).  The range of downstream power levels is too high, from 3 dBmV to 9.4 dBmV, that's likely to cause problems for the hub, and your Network log is full of serious and frequent errors.  There's also the occasionally seen repeated "Atom is restarting as part of self healing", which I speculate means the hub itself is faulty (VM are singularly unhelpful in not saying what that means).  I'll flag your post for the forum staff since there's nothing more we community members can do.
