ELG31
Panasonic V6 Remote Volume
V6 Remote works with TV, everything except volume and mute. These buttons flash green not red when used (working buttons flash red when used). Reset control several times and re-paired using V6 box, the Panasonic TV codes and even tried AV audio codes. Please help! Very frustrating having two controls to use one for V6 box and one for TV volume!
jb66
  • 12.14K
  • 899
  • 1.75K
Re: Panasonic V6 Remote Volume
Did 0032 not work?
ELG31
No that did not work. We tried all the codes that were prompted including that code
  • 5.67K
  • 911
  • 1.33K
Hero
Hi ELG31,
sorry to see you are having problems setting up your remote.
There's a list of codes here which you may want to try TV Remote Code List
There was a forum post 3 weeks ago with another customer having issues setting up their Panasonic and this worked for them
Go to HOME > Help and Settings > Help > Set up Remote.  Follow instructions there it should give you a series of codes to try.  You can also put 0999 in place of the code and press channel up until the TV turns off, then press ok.
Dave
nodrogd
  • 16.45K
  • 1.92K
  • 3.93K
The remote only flashes red when sending RF Codes to the V6. It flashes green when sending IR codes to other equipment.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
ELG31
Yes! This worked. Thank you so much!
