I recently bought a new Philips TV and soundbar, and I've noticed an issue with the sound level from my TiVo V6 box.
I've noticed that any channel that outputs in PCM audio is a lot quieter than channels that output in Dolby audio. This is not something I've noticed before because this is the first time I've had anything capable of Dolby audio.
If I set the V6 to PCM only, then obviously all audio goes quiet. And certainly a lot quieter than the same channels on the TV's Freeview receiver.
And I know it's not a problem with the TV itself because the disparity persists when I connect the V6 directly to the soundbar via an optical cable.
Is this a common known problem?
