Billwalton59
Ordering a replacement remote
I have tried multiple times ordering a replacement for a damaged remote online through my account but although everything seems to be in order when I get to the final confirmation screen a message flags up saying a technical issue has arisen and I need to order again. This ha happened many times over the Las 2 days. Please advise if I am ordering incorrectly or alternatively how else I may order one.
Regards,
W. Walton
  • 6.44K
  • 1.01K
  • 1.59K
Re: Ordering a replacement remote
Hi BillWalton59,
Have you tried using a different browser, or clearing the cookies/cache on your current browser?
You should be able to order a replacement by logging into My Virgin Media at the top of the page, or by using this direct link  Order new remote
You can also try the TV Faults option when dialling 150 or 0345 454 1111, but best to call at 8am -10am, or afternoon teatime to avoid call queues
You could try the text messaging service.
Just send  a text with a description of new remote  to 07533 051809. Your message will go into a queue and a representative will respond to you as soon as possible. It may take a few days.
For now you could download the TV Control app and use that until you receive a replacement remote
https://www.virginmedia.com/shop/tvgo-tvcontrol
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
Billwalton59
Needed to ring 150 in the end as all other options failed. Thanks
  • 6.44K
  • 1.01K
  • 1.59K
Hi again Billwalton59,
Thanks for the update.
Don't forget to download the TV Control app as per my other post to use as a temporary measure until you receive the replacement remote.
Stay safe and take care.
Dave
