  • 46
Dialled in
Message 1 of 14
Occasional loss of sound when changing channels
I am getting an occasional loss of sound when I change TV channels, I have tried the Settings-Video Output Format-Auto Detect and also Settings-select network-connect to Virgin Media ideas without success.
Tonight when I lost sound on a channel, I went to Settings-Sound Test on my TV, the sound came on with a message that there was not a sound problem with my TV, I then went back to the channel, and again no sound.
It was possible to get the sound back by channel hopping until I found sound, then the original sound loss channel would be OK.
To confuse matters I do have a TV that is only 2 weeks old but I did notice losing sound a few times on my old TV. Reading all the posts about loss of sound a new HDMI cable will not cure the problem, I believe that I need a replacement V6 box, do I have to ring for an engineer?  TIA.
  • 3.85K
  • 234
  • 427
Message 2 of 14
Re: Occasional loss of sound when changing channels
Hi gus0898uk,
Thank you for reaching out to us in our community, I am sorry to hear you are getting an intermittent issue with sound.
Is this happening on specific channels?
Have you tried to change the HDMI cable/ port to see if it still occurs?
Kind regards
Paul.
  • 46
Dialled in
Message 3 of 14
I have a new 4K hdmi lead coming tomorrow so i will see if it improves things.
I can change channels and lose sound then sometimes when I go back the sound is there.
At the moment it is just frustrating, I will report back whatever, hoping the new HDMI lead solves the problem.
  • 3.85K
  • 234
  • 427
Message 4 of 14
Please keep us informed once you receive the new cable.
Paul.
  • 46
Dialled in
Message 5 of 14
Well the new 4K HDMI lead came and I am still having intermittent loss of sound problems.
This morning I was watching the TV, 101-sound,102-sound,103-no sound,102-sound,101-sound,102-sound,103-no sound,104-no sound,101-sound,102-sound,103-sound,104-sound.
That is typical of the fault, I can scroll up and lose sound, scroll back and the sound may be there or may not.
It is only an intermittent fault.  TIA
Regards Paul
  • 3.85K
  • 234
  • 427
Message 6 of 14
Hi Paul,
Thank you for getting back to me and for the update, really sorry to hear the HDMI cable hasn't resolved the issue, I have checked things our end and I can see there is work being carried out as a fault has been picked up, this is showing as being fixed today by 16:00 the fault code is C01083403.
Plesae let us know after this if you are still experiencing this as this may be connected.
Paul.
  • 46
Dialled in
Message 7 of 14
Thanks very much Paul, I will let you know one way or another, thanks for taking the time to help me on this. Paul G
  • 46
Dialled in
Message 8 of 14
Paul
I am afraid that I still have the occasional loss of sound problem, it is not too bad, but it does need sorting.
Do I need to get an engineer out?
Regards Paul G
  • 2.63K
  • 197
  • 266
Message 9 of 14
Sorry to hear that this is still going on gus0898uk. I have looked into the back end of your system and have been advised to stage this issue to our 2nd line faults team, who will look into this and contact when they have found out what the issue is and resolved it for you. This should be in the next 24-48 hours that they will come back to you.
Steven_L
  • 46
Dialled in
Message 10 of 14
Yesterday I had a phone call from a Tech lady in India? and so far so good. Fingers Crossed. 🙂
Home button on Virgin remote, Help & Settings. Settings, Audio, Dolby PCM
It is still a bit early to tell but I do feel confident, we shall see. 🙂
