dustybin154
  • 7
Message 1 of 7
Noisy V6 box
My TiVo 6 box has started.making very loud vibrating noises intermittently that can be heard over the TV
Do I need a new box? I could hear the fan before if everything was off
LittleMick73
  • 5.03K
  • 520
  • 864
Superstar
Message 2 of 7
Re: Noisy V6 box
Hi this sounds like the hard drive is failing call 150 free from a virgin phone or 0345 454 1111 from any other phone go down the TV faults route. Regards Micky
dustybin154
  • 7
Message 3 of 7
Re: Noisy V6 box
I've tried to follow your advice which is much appreciated it just runs checks then says everything is fine thanks for calling and hangs up.
japitts
  • 12.04K
  • 1.67K
  • 2.58K
Message 4 of 7
Re: Noisy V6 box
Quite often the automated system will try running diagnostics and remote fixes and then decline to put you through to a faults agent. Calling back 10minutes later when the fix has failed, tends to get you into the queue in these instances.
Chris_W1
  • 4.06K
  • 185
  • 255
Message 5 of 7
Re: Noisy V6 box
Hi dustybin154, thanks for the message and we are sorry to hear that the set top box is not functioning as it should be. This will most likely require an engineer to resolve. Can you confirm if you have managed to speak to us regarding this or still require assistance? Chris.
dustybin154
  • 7
Message 6 of 7
Re: Noisy V6 box
No I havnt managed to speak to anybody yet keep getting the same automated service so yes I still require assistance please
Chris_W1
  • 4.06K
  • 185
  • 255
Message 7 of 7
Re: Noisy V6 box
Hi dustybin154, thanks for the reply, I will send you a private message to get this looked into for you. Chris.
