Cymro49
  • 18
Message 1 of 9
No surround sound when using V6
I have recently purchased a new OLED LG Tv connected to LG sound bar and surround sound speakers.
My connections are high grade HDMI from the Virgin V6 to the HDMI input on the TV.
The output from the TV is on HDMI E-ARC to the HDMI Arc input on the sound bar.
When using the Netscape app on the TV I get surround sound, proving the system is OK and the problem is the Virgin V6.
If I connect an optic cable from the V6 output directly to the soundbar optic input with the HDMI Arc cable disconnected from the TV I get surround sound.
This proves there is a problem with the surround sound output via the HDMI port of the V6 Box.
I would be grateful is someone can help me on this.
japitts
  • 17.24K
  • 2.25K
  • 3.97K
Message 2 of 9
Re: No surround sound when using V6
Is this on all content, or just specific channels/broadcasters/OnDemand?
Only asking because ITV HD is notably only in stereo and not Dolby.
Cymro49
  • 18
Message 3 of 9
It is on all 5.1 sound contents on virgin.
Roger_Gooner
  • 7.52K
  • 507
  • 1.39K
Message 4 of 9
What's the TV's Sound Out setting? If it's PCM you'll get stereo.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
Cymro49
  • 18
Message 5 of 9
I have it on Dolby digital not the pcm
LittleMick73
  • 5.39K
  • 547
  • 923
Superstar
Message 6 of 9
Hi the HDMI port on the V6 should be used to go to the TV, so the fact that using an optical solves your problem should tell you that's the way to go. Regards Micky
Cymro49
  • 18
Message 7 of 9
I am using the HDMI from the V6 to the TV, This works but only carries 2 Chanel sound not 5.1. That’s why I have had to connect an additional optic cable from the V6 box to the sound bar in order to get surround sound.
Lee_R
  • 4.99K
  • 237
  • 507
Message 8 of 9
Hi Cymro49 thanks for posting.
I am really sorry to hear you're unhappy with the sound capabilities of the V6 box. Please can you confirm if you're a single box or multi-box user and if multi-box, does the issue exist on both boxes?
Lee
Cymro49
  • 18
Message 9 of 9
I have found the problem with the sound.
The new 4K HDMI 2.0 cable had a fault. I used a temporary cable as a trial on a surround sound channel and it worked.I can not disconnect the optical cable.
Thanks for all your assistance  commence.
