Ian-64
No sound with Sky cinema on-demand
When we try to watching films from Sky cinema on-demand service the sound stops after a couple of seconds. Picture quality is fine.
All other "on-demand" streaming services work perfectly (Netflix, Amazon Prime, i-player etc).
Tried changing the HDMI cables.
Is this a known issue, and how can I fix it?
japitts
  • 18.53K
  • 2.4K
  • 4.24K
Re: No sound with Sky cinema on-demand
You've mentioned streaming services working ok, but how about other OnDemand programmes?
Apart from BBC content which uses the iPlayer app, all broadcasters use the same OnDemand technology - so if you have a VoD fault, it should affect all channels/programmes regardless of broadcaster.
If not - then are there any specific films/programmes that you're having issues with?
Ian-64
Thanks for your response.
Everything works fine (Netflix, Amazon, iplayer, More 4 etc), except when trying to watch an on-demand film from Sky Cinema.
This has been going on for a white with varying degrees of problem.
I rebooted the box last night, and it seemed to work OK. Haven't tried today.
Ashleigh_C
  • 3.74K
  • 152
  • 288
Hi there @Ian-64
Thank you so much for your first post to our Community Forums and welcome to the team, it's great to have you on board!
I am so sorry to hear that you are facing this issue with your Sky Cinema and thank you to @japitts for their advise!
I have had a look on your account I can see the box is currently turned off, are you able to turn this on for me so I can run diagnostics?
Thank you.
Ash_C
