No sound when i turn tivo box on
RichardJ3
Over the past month or so, when I turn the TiVo box on (v6) there is a picture but no sound.  It's the same on all channels and recorded programmes . The Tv on its own works fine.
If I turn the TiVo box off and on again, it usually fixes the issue, but this process takes approx 10 minutes it's everytime.I
Any help gratefully received.
3 REPLIES 3
Anonymous
Not applicable
japitts
If restarting your V6 clears the problem for a while before it recurs, that lends towards a software issue - but.... have you tried another HDMI cable, and another HDMI port on your TV, to eliminate a fault there?
Kain_W
Hi there RichardJ3,
Thanks for raising your query and welcome back to the community.
Really sorry about the issues faced, from checking our service I can't currently see any readings that would attribute to the issue, is it still occuring?
Let us know,
Kain
