on 28-07-2019 17:53
I Cannot get sound on the sky sports red button channels.
Been trying to watch the golf but either no sound at all or earlier on it was Formula 1 commentary over the top of the Senior open golf.
this also happened last week when I tried to watch via the red button
can you let me know if there is a fix?
many thanks
Catherine
Answered! Go to Answer
on 28-08-2019 14:55
Hi thanks for getting back to us.
If this is continuing can you check the audio settings please? If they are set to Dolby Digital, try Dolby Digital to PCM instead.
To find the audio setting follow - Home > Help & Settings > Settings > Audio
To test if the issue has been fixed channel up and down then tune to an HD channel, press "Pause" and then "Pause" again to resume playing.
David_Pn
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
on 31-07-2019 14:44
Hi Cathykil,
Thank you for getting in touch,
I am very sorry to hear you are having problems with sound when using the red button channels.
I'd like to take a look in to this further for you.
Can you please confirm if you are still experiencing this issue and if you experience the drop in sound when using any other interactive / OnDemand service?
Thank you
on 21-08-2019 19:48
Sorry it’s taken so long to reply, first time I have had the opportunity to try the red button. I have tried again tonight with the EFL championship matches and there is no sound on them either.
it comes on for a split second and then is gone.
on 28-08-2019 14:55
David_Pn
on 08-09-2019 09:25
Thanks, this looks to have resolved the problem for us 👍🏼
on 29-12-2019 15:28
on 31-12-2019 11:06
Hi LeeBeales,
Thank you for reaching out to us in our community and a very warm welcome to you, I am sorry your football was spoilt due to the issue with the red button at the weekend.
This was reported as an issue with Sky this has now been resolved, if you do have any further issues please do not hesitate to let us know.
Kind regards
Paul.
on 31-12-2019 17:33
hi
thanks I tried the work around it has solved it 👍🏼
many thanks
cather
on 31-12-2019 17:45
Glad to hear that this has worked for you Cathykil.
Please let us know if you have any further problems.
Steven_L
