gringosmith
No sound intermittently on channels and recordings
I have recently had your broadband and tv package installed and have found there is a sound problem with the tv box. Sometimes after switching between tv channels, recordings, or apps the sound stops working. I have tried every button on the remote to clear this but generally the only solution is to turn of the tv box at the mains and restart it. The box is plugged straight into the tv with no soundbar. Sound is otherwise perfect. Please advise. Neal Smith
  • 8.09K
  • 1.18K
  • 2.23K
Re: No sound intermittently on channels and recordings
Hi Neal,
Using your remote to to HOME > Help & Settings > Settings > Audio > Dolby Digital > and click on Dolby Digital to PCM
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
gringosmith
Thanks. I have changed this and will let you know if it cures the problem.
gringosmith
Since making the changes I have had no more issues with sound.
Thank you very much for your assistance.
