David83val
Message 1 of 10
No sound intermittently on channels and recordings
I have a strange issue, intermittently I change to a channel and get no sound, it seems more prevalent on the music channels, it’s even happened on a recording. If I switch channels and then back it corrects itself. This happens both through my soundbar connected through ARC and through the TV’s speakers.
My V6 box is connected through a good quality HDMI to a 2019 LG TV. I didn’t have the same problem with my previous setup. (Samsung Tv and soundbar)
it has me baffled.
any ideas welcome.
Tags (1)
Emily_G
  • 4.78K
  • 207
  • 293
Message 2 of 10
Re: No sound intermittently on channels and recordings
Thanks for the post David83val and welcome to our community.
Can we please confirm if you've already been in touch with the team to look into this?
If not, can you please go through the below steps:
Home> Help&Settings> Settings> Network> Connect to Virgin Media Service Now
Thanks, Emily.
David83val
Message 3 of 10
I have not been in touch, I have tried the suggested steps and all says finished
not sure what I achieved though.
regards
dave
Emily_G
  • 4.78K
  • 207
  • 293
Message 4 of 10
Are you able to check if this has resolved the issue at hand?
Thanks, Emily.
David83val
Message 5 of 10
No this didn’t fix it 👎
Emma_C
  • 8.28K
  • 511
  • 556
Message 6 of 10
So sorry for the delay in replying to you David83val,
If this is still happening now can you try a factory reset of the box, select the option to keep recordings should you wish to and then test the channels again?
Emma_C - Forum Team
David83val
Message 7 of 10
Tried that, no joy
Emma_C
  • 8.28K
  • 511
  • 556
Message 8 of 10
No worries, I'd like to take a look at your account but sadly I can't find it using the details you signed up with.
Therefore I'll pop you a personal message and grab some details.
Emma_C - Forum Team
tonymcf
  • 29
Message 9 of 10
Hi, I have a similar issue.  Only manifested a day or so ago, there will be a break in the sound fo a couple of seconds, very 30 seconds or so?
I've checked the HDMI cable at TV and Tivo box and conducted an HDMI test; all OK?  I have changed the video output to 1080 (passthrough) as suggested by a Virgin tech in an earlier post.All to no avail.
This phenomenon only occurs on the HD channels??????????
Help
  • 5.76K
  • 916
  • 1.36K
Hero
Message 10 of 10
Hi tonymfc,
Does going to Home > Help & Settings > Settings > Audio > Dolby Digital > Dolby Digital to PCM cure this?
Dave
