Message 1 of 7
No power to v6 box
There is no power on my v6 box. I have checked all cables and that is all fine. No power light etc. Not sure when or how it happened as been watching Netflix on smart TV. Has the box blown?
  • 30.33K
  • 1.51K
  • 5.26K
Message 2 of 7
Re: No power to v6 box
have you tested the box plugged into another socket.
If it not working after testing it in another socket contact VM. It might just be the power cable.
Due to the current situation there is a text message only service is available via: 07533051809 Just send a text with the issue you are facing and someone will get back to you as soon as they can.
  • 152
  • 35
  • 61
Message 3 of 7
The V6 Box has a power switch on the back of the box just check that it is switched on.if you still have a issue after that PM me with your account number and site id.
Please click on the thumbs up icon
Kind regards Darren Hollands
Access field tech 20279
Ger 50 pounds off you bill when you refer a friend to virginmedia.
Message 4 of 7
Thanks Darren.
The switch on the back is on. I have tried different sockets and also tried a different lead as I have a box upstairs too. Nothing has worked so I think it must be the box.
I will PM you now. Thanks.
  • 46
  • 25
Message 5 of 7
If you send a text message to this number 07533051809 with all your details inc acc number address fault etc someone will be in touch to have a visit or a replacement box sent.
Cheers
Paul
Field Technician 71589
  • 607
  • 37
  • 95
Rising star
Message 6 of 7
@Laurenb wrote:
Thanks Darren.
If the box upstairs is working and it's a V6 then you could try using the power supply 'brick' from that. This should confirm if it's that or the box that's failed.
Message 7 of 7
Thanks, that's what I meant by I tried an extra lead. Must be the box I think. Thank you 🙂
