newcust1988
  • 60
  • 6
No picture, but menus and sound are fine
Hello
Ive been with virgin a couple of weeks and everything was fine. A couple of days ago i started getting no tv picture on the channels. I also cant see the pictures on apps like bbc iplayer or youtube.
The sound works fine, i can see the menus, tv guide, recording, i can see the iplayer menus and youtube menus all fine. But as soon as i click play, i just hear the sound and no picture untill i click back onto the menus and then i can see the menus again.
Ive tried the obvious fixes like restarting the box, changing the hdmi cable/port but the problem continues. Ive also plugged another device into same hdmi port which works fine, and the tv itself on freeview and its own apps works fine. So the problem definitely lies with the virgin box.
Can anyone help please? Thanks
LittleMick73
  • 4.8K
  • 497
  • 819
Superstar
Re: No picture, but menus and sound are fine
Hi you could try a forced connection, go to help and settings, settings, network, reconnect to the virgin media network now. Regards Micky
japitts
  • 8.56K
  • 1.2K
  • 1.66K
Do you have a TiVo or a V6? You've posted in the V6 section but referred to a TiVo.
If you're not sure, check here
nodrogd
  • 16.18K
  • 1.87K
  • 3.82K
Seeing menus & non-channel related material would point to a handshake failure between the box & the TV, which is required to "unlock" the copy protection.
If you have tried new cables & the other ports then the fault lies either with the box or the TV not processing HDCP correctly.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
newcust1988
  • 60
  • 6
Hello, sorry, its a V6 box i have. My apologies.
Its worth noting, sometimes it works by restarting the v6 box, but that doesn't always work.
newcust1988
  • 60
  • 6
Is this something can just "occur"? Everythings been fine with sky and virgin for years until a few days ago
