Colinrudd1954
My tv keeps showing check signal cable ,ive checked them its still the same
my tv says check signal cable ,done that still the same
japitts
  • 19.28K
  • 2.5K
  • 4.41K
Re: My tv keeps showing check signal cable ,ive checked them its still the same
That's not an error message a TiVo/V6 tends to generate, which makes me suspect it's a TV error. That in turn would point at an HDMI problem - have you tried another cable or port on your TV?
Any error generated by your VM box will have an error code/number with it.
Zak_M
  • 6.12K
  • 315
  • 545
Good morning @Colinrudd1954
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you are having some issues with your TV services.
As advised by Japitts, this does sound like a TV issue instead of a problem with the virgin media box.
How are things looking since your post?
Kind regards,
Zak_M
Roger_Gooner
  • 8.32K
  • 540
  • 1.57K
I would try pulling your TV's power cable from the wall socket, waiting 60 seconds and plug back in. This sometimes resolves cable signal errrors.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
