scottatkin1
  • 7
My TiVo box won't work!
Hi my TiVo box is not working. I try to reboot then it stops working again. I've tried to reset. But the same happens! I need a new one sending please. Asap!
japitts
  • 8.54K
  • 1.2K
  • 1.66K
Re: My TiVo box won't work!
Is it a TiVo or a V6 you have? If you're not sure, check here
In what way is it "not working" - can you explain, and then perhaps we can help?
