audioman24
  • 13
My Shows Playback on v6 box... help please
Hi All,
Does anyone know if it is possible to make the v6 play continuous following episodes on the my shows . I know that you can tell it to play all, but i mean selecting an episode and playing on from there. When i select an episode it stops and asks if i want to keep the recording instead of just playing the next episode.
thanks for any help
Ernie_C
  • 18.4K
  • 2.01K
  • 4.5K
Re: My Shows Playback on v6 box... help please
You can only play all from the oldest recording (why would you not have deleted the earlier ones if you don’t want to watch them?) but once you do, you can press channel up when you’ve watched one to go to the next.
